Hello,
I'm getting ready to install a new DVD player head unit and amplifier. The DVD player is going in the glove box and the amp in the trunk at the stock amp location. I've had problems with noise before so I would like to avoid splitting and soldering wires to use the stock connections.
Both the DVD Player and Amp have RCA inputs for the two channels so what I would like to do is run a very high quality 2 channel RCA cable from the glove box to the trunk. Where should I run the wire in order to avoid the least amount of noise and physical stress? Would thru the back seat and under the transmission tunnel be ok?
PS..
Since the car has 10 speakers and the AMP only has two channels you just twist all the right speakers + and - into one terminal and all the left speakers + and - into the other terminal, right?
THANKS!!
PS..
THANKS!!
